Hummina Shadeeba
I've found u can reterminate a motor to wye outside the motor, which I've found a lot easier than opening it up and somehow removing the bearing tube. I'll do it later if all else is good. This'll give it more needed torque which is needed since there's no gearing.
But...the one in this pic sits with the bearings stuck on with "retaining fluid". Pretty much glue. My better recent attempt I'm using a tacon 160. Probably harder with its length
The rotor holds it's position on the axle by being bolted to a 2 inch bearing-filled tube that sits in the wheel.
