waratte
Hi again, I have a new problem with my new motor. At first my ebike ran very well, clean, quiet, and fast, with only one hiccup.
Sometimes when I started my ebike and hit the throttle, the motor spinned but it met massive resistance, causing me not to gain any speed at all and my bike vibrates loudly from trying to overcome the resistance. Usually, the problem would fix itself after 5 minutes and the bike ran clean like normal after that for the whole day.
Now, it seems that the resistance has increased so much that all the wheel does is jerk forward about an inch or so and stop moving and it hasn't gone away yet. Every time I hit the throttle, the wheel just jerks a little bit then stops. This happened after I was rolling backwards down a flat sidewalk and tried to stop it using the throttle.
Also, I have noticed that it has become really hard to pedal. Before, I felt like I was pedaling with no resistance from the motor, now the resistance is pretty strong and causes my bike to vibrate as I pedal.
Anyone know what has happened to my motor and is there any way I could fix it?
This is the motor I have by the way: link.
If I can't fix this problem, could anyone point me to a more reliable kit or motor I could replace that one with (preferably as easy to install, similar specs, and a hub motor too)
