Electric Horsemen
- Joined
- Aug 13, 2022
- Messages
- 4
PRICE $3,500 (AUSTRALIAN DOLLARS)
One-off high end build based on the NYX carbon space-frame. NEEDS BATTERY and CONTROLLER and THROTTLE. Full custom build including hot-rod hub motor with cooling fins and ferro-fluid. Full 12V system including headlight and indicators etc. Custom wheels built with motorcycle rims and Pirelli tires. 203mm discs front and back. Dorado brake levers and ZEE calipers - plumbed with Goodrich braided brake lines (all ADR approved gear). If you are looking at building a high-end, high-power e-bike this is about as good as it gets for a rolling chassis. Had this baby running at peaks of 14KW.... suited to running at LEAST 5KW. I bought this back off the customer (at 5K) after he let the battery run flat - need to re-coup some of the cash. Will ship anywhere in Australia - and go you halves in shipping. Free drop-off or pickup in Southern Tasmania.
