Hello ,
new user to this forum , does anyone know of a way to talk to the M37510 chip on the Panasonic BMS boards used on the DARBY Cycle batteries used on Kalkhoff bikes
When I purchased the bike some two and a half years ago I bought a spare battery for touring , and recently just a few months after the warranty ran out my spare went dead , I have opened the box and discovered its a fairly simple affair totaling 70 cells .
the re sellers of these items want over 700 euro for a replacement battery , I am not inclined to buy a new battery !
Pack1 42 18650 cells 6 banks of 7 in Parallel.
Pack2 28 18650 cells 4 banks of 7 in Parallel giving 36v @14aph
The controller board appears to use the M37512 BMS controller chip , I can see the I2C clock and data line and the leads off the cells are clearly marked and color
coded so I don't see any problems replacing the cells as I have access to a small spot welder and I fully intend to replace all the cells (at least the ones I cant revive)
my problem is when I do replace the cells and reconnect up the BMS board how can I get the new battery information into the board , I assume the controller
will have stored all the parameters of the old cells (from when the pack was last working) , is there a simple way to communicate with the board or am I better off
buying a completely new BMS board and replacing it when I replace the cells ,??
any help or suggestions would be appreciated !
rovtec
rovtec
