phaserunner+gyro=EUC???
goatman
Surrey, B.C.
looking at these EUC's, theyre very simple but very proprietary
looking at building one
is it really as simple as wiring a gyro to the throttle and regen of the phaserunner and then just use the PR to program the wheels ramp up and ramp down rates.
just need to find the right gyro, no?
just putting a link to a motor here
https://www.uumotor.com/ws/p/18x9-5-8225-55-8-60v-1000w1500w-brushless-dc-fat-tire-motor/
its what the bublick uses
https://www.youtube.com/watch?v=vh1ze0omhqI
the bublick controller can be used for self balancing machines or ebikes
sent an email to try and get one
3 axis gyroscope that acts like a potentiometer
https://mhpro.net/online/en/gyroscopes/mhpro-net/3-axis-gyroscope-that-act-as-potentiometer-analog-outputs-p78
trying to figure out how to switch from forward to reverse
the gyroscope can work the throttle and brake and shut off
i was thinking an accellerometer could switch from forward to reverse but when braking at speed it would probably to switch to reverse when tilting back while still going forward
then i thought maybe the motor speed wire could be used to switch for/rev at zero km/h
does anyone know what that switch or sensor would be called?
would a balance board from a hoverboard work?
got a tip from supercurio on another forum to check out freedom caller's youtube
he did exactly what i want to do
https://youtu.be/6pIQrDrMwQY
vesc controllers
https://trampaboards.com/vesc--c-1434.html
