Twistgripper
- Joined
- Sep 20, 2019
- Messages
- 35
Hi all, just looking for a low cost controller and display that will be compatible with a Bafang G60 36v 500w fat motor
(RM G060.500.DC 07, 008F1S3270645, G60_STD 8.2 Rpm/v).
I'm ok with buying from Aliexpress/amzn/ebay.
Requirements: sensor or sensorless compatible, z9 plug type but can rig up pigtail if needed (i have an adapter), 17-22 amps peak. Pedal assist sensor compatible, and preferably with a 12v output for headlight/taillight.
I've read that motors and controllers need to be matched or the phases may be not synced up right??? not sure i understand and Grin was not very helpful just mentioned doing the "36 step pinout dance" or something like that, which im sure i could learn but havent found a good video "how to" on that yet.
does the controller angle rating matter (60 or 120 degree)? - could not find that spec anywhere on this motor.
Background info if you care to read:
I have a Grin Technologies fat rear hub kit with issues I cannot seem to test for using the standard no load tests. Either motor or controller has a problem that only exhibits itself under load (riding the bike). Controller is Grinfineon 20a, display is cycle analyst v3.1 which i really dont like (too much info/settings, really dont want that) as i will be selling bike and want to make it more idiot proof for the next owner. Just trying a known good controller could save me a lot of time and headaches...so i can rule it out or find out if the controller was the problem.
