Uplink
I was hoping someone could enlighten me on this BMS/charging issue I am having. Have this 37v 15AH LiPO battery with 3 amp charger I bought from EVtech last year. Usually, when you plug in the charger you get an amber power light, and a red charge light that turns green when the bat gets to 42.1v. The other day when I plugged it in, it started with the green light on, and didn't send any noticeable amps to the battery. At first I thought I had a charger problem.
Tested no load voltage on the charger: 42.1 volts. Load plug on battery: 39.2v. Charger plug on the battery 38.8 volts. Hmmm. Why should the battery have different voltages on the load side and the charger side? Never tested that before, so I don't know if that is normal or not. Tried hooking the charger to the load side of the battery, and got the red light and amps flowing. Hooked it back up to the charger side, and still no go.
Any help with the following questions would be greatly appreciated:
1. What could be the problem here?
2. How can I fix it?
3. Can I get away with charging through the load side of the battery?
4. Am I going to have balancing and safety issues if I charge the battery through the load side?
5. Is 700 miles all you get out of a $650 battery?
