nomad123
100 µW
- Joined
- Oct 5, 2017
- Messages
- 8
Hi all,
I built a 30P12S battery pack using 18650 cells (3.7V Nominal). To house the pack I made a frame out of square tube Mild Steel.
The problem I am facing is that, when I install the pack in the frame I get a positive reading on the voltmeter between the negative of the battery pack and the frame. The voltage reads 7 to 8 Volts. If I hold one lead of the voltmeter in my hand and place the other on the negative terminal of the battery, again I get a reading but of 3 to 4 Volts. Doing the same with the positive terminal results in a low voltage of about 0.5 Volts.
There is no short circuit. The reading between battery positive and negative is 48 Volts. So there is no voltage drop in the battery itself.
What is causing this voltage? Is it harmful?
Google hasn't been able to provide me with the answers and I am not sure what to search for. After a lot of head scratching I am hoping I can find some answers here.
