tomtom123
i got 3 mains questions:
1) What's the difference between the Bafang 36v 500w motor vs the 48v 500w motor? the 48v just provides more speed right? and it is even worth it cause i can technically get to 36v to run at 48v without really damaging it and achieve the same speeds right?
2) The reason i'm asking is because i want to get the 48v motor, however getting a 48v battery with higher AH is expensive compared to getting a 36v battery with higher AH, and i want more range and torque. i'm thinking of getting the 48v motor and get a high AH 36v battery. However, several posts in the forum mentions that it won't work cause the 48v motor has a voltage cutoff rate of about 41v and so i can't use the 36v battery on the 48 v motor? this would mean i need to get the 36v motor instead?
3) is it worth it for someone who lives in NYC to buy a 48v 500w motor or should i get a 36v 500w and get a 36v battery with 20ah that would provide me more range and torque and cost around the same as a 48v 12ah battery. Would the 36v motor with 36v battery provide with me enough speed? i would like to be around 20 mph if possible on flat roads and i weigh 200 lbs and the mongoose bike is around 40 lbs
an answer to any one of these questions would suffice, and answers to all 3 would be great :lol: thanks in Advance!
