dogman said:
Size of the battery matters a lot too. Take a typical 12s RC lico pack in 10 ah. Below 3.5v per cell, there is literally only about a block or two of riding left, even at 10 mph.
But increase the pack size to 30 ah, and less voltage sag makes wringing that pack completely dry work better. You may actually have a couple miles or more left below 3.5v. With nearly no voltage sag, you can ride deeper into the pack with less worry. With a small pack, the sag makes you freak out and stop long before you go below 3v.
With a small pack, the sag really increases below 3.5v. But a 150w discharge doesn't sag a huge pack.
for me the cellogg cuts in on one channel when i am climbing above about 110A current draw from the batteries. that is usually at the end of the discharge from the lipo pack at around 44Ah, but by then the 110A draw is coming from the 24S ping pouch pack and nothing from the lipo pack. in fact the lipo pack discharge essential stops at one point in the combined discharge even while tied in parallel with the lifepo4 but increases as the lifepo4 gets drawn down to about 69V so i shut off the BMS on the lipo pack when it keeps beeping under a 40A load which gives me a rebound to about 3.5V on the low cell, and usually about 3.7V if i can turn it off when i first hear it. but i have to manage the batteries carefully to get the maximum range of 96 miles. that took 7 hours to finish counting time i was broke down on the road when i overcharged the lifepo4 pack by accident. so i don't think i have quite that much range any more because i have one cell that was damaged by the over volting during the overcharge and it is acting lame. but my pack is so huge it will not be worth the time to find it now.
the overvolting on the cells was so high that i burned out one of the leds on a ping signalab BMS. so high enuff to push enuff current through that 1kR resistor to burn out the led. maybe 20V?
