RAZOR PR200
acer900
Hello,
I'm extremely new to all of this moddying, but I wish to start asap! I have two questions for you guys. I currently have a PR200 with three 12V 7Ah battery and everything else is stock, please apply this to my questions below.
I have a budget of 160$ and I wish to have a average speed of AT-LEAST 25MPH (I'm 125 pounds) and I want to have a maximum traveling time of about 30 minutes but this isn't really important the speed is more important to me. Is this possible with 160$? If yes can you please make a list of the parts I should add to my PR200?
I have three 12V 7Ah with everything else stock. How do I wire it without busting my controller (Max 24V and 29Ah)? Can someone please draw a quick diagram?
Perhaps you could help us to help you by also posting the specs of your starting point e.g mph, motor type, range, gear ratios. So, is that a scooter?
Start point is 15mp, motor type is stock razor 24v (here's it http://www.monsterscooterparts.com/24v-250w-motor-e300.html), I don't know the range and gear ratios. What is gear ratios though?
For a brushed motor, i think the best thing to do would be wire the batteries up in series and bypass the controller entirely. just put a switch between the motor and batteries for on or OFF. see how fast that goes, if it doesn't go fast enough, add another battery for 48v. This would not be safe though. Also, this might toast the motor, but if it does your only out 30 bucks to replace it.
