Red Insulation Lacquer
Here's a DIY Motor Repair thread where DrBass recommends Sprayon A00601A00 Red Insulating Varnish.
Here's the original DrBass motor repair thread.
Product Blurb:
  • Sprayon Red Insulating Varnish
    Item # A00601A00 EL 601
    Sprayon® EL™ 601 Red Insulating Varnish is an insulating spray for general coating, impregnating and insulating electrical and electronic work. Excellent adhesion to metals, windings, coils. Air dries faster than most insulating materials. Protects surface against oils, moisture, acid and alkalis. Perfect for small field and magnet coils; penetrates oil and new windings; has excellent flexibility and water resistance.
    Uses: Motor windings, field coils, transformers, armatures, commutator ends, stator windings, ring and frames, bus bars, sealing electrical, switchboard parts and electronic components
    Air Dries In 10 Minutes Or Less
    Dielectric Strength: 2,600
    Meets Class F Requirements (155 degree C)
    Resists Oil, Moisture, Acids And Alkalis
    Meets Performance Requirements Of ASTM D115-07 4.2
    Penetrates thoroughly and forms a tough, flexible film
    High arc resistance and non-tracking properties Excellent adhesion
I would recommend getting it from Grainger if you are in the states. Not sure about Europe though:
SprayOn
