Replacing Hub Motor Brushes
It shouldn't be too hard to get the side cover off. It might be necessary to use a gear puller to extract the magnet ring from the armature. Avoid letting the magnets slam when you put it back together.
I've never seen the guts of a WE motor, but it should be similar to this one:
In the "E-Scooter and Motorcycle General Discussion" Forum there is a thread "Cleaned My EVT hub motor out" that has great pictures. There is also a reference to "www.7gen.com/book/my-ev-projects/cleaning-evt-hub-motor/701" that shows details using a gear puller to seperate the motor parts. On a spoked hub I should be able to hook onto the spoke flange instead of forcing the cover off a little and hooking onto the cover. Since everything is working good right now I'll probably just order a few sets of brushes from WE and be prepared.
http://www.7gen.com/book/my-ev-projects/cleaning-evt-hub-motor/701
