mwkeefer
Hello all,
I just found a good source of 26" rears but they sadly had the coaster brake version of the 3SPD Nexus.
In teh good old days you could disable / remove the Coaster Brake mechanism (not the arm) by opening the wheel and removing the Brake Pad Unit (circular little bugger) and replacing it with hard spacing (washers) and perhaps a spring to eliminate any wobble (I always used a length of pipe - but that's me...
So does anyone know if this is feasible and similiar with a internally geared hub as I would like to remove the coaster pads unit all together to prevent possible friction heat building and intoduce true freewheeling hub.
Buying a new hub for 26" is not an option - after this its a full wheel build but I can get these for a reasonable price in fair quality so if they can be modded correctly - I'm crazy not to!
Thanks in advance for any help or suggestions!
-Mike
-Mike
