SHARKBITEATTACK
Home Depot has a sale today. 2 of there 18v 4ah Lithium+ batteries for $100. Anyone have experience with these?
wheelbender6 said:If my calculations are correct, and they rarely are, you would need four of those batteries for 36v 8ah. Individual batteries would be wired in series to form pairs to double the voltage. The pairs would be wired in parallel to double the amp hours?
davec said:based on the msds it looks like it is using 18650 cells LG18650HB2 Lithium Ion Rechargeable Battery
chemistry: Cobalt lithium manganese nickel oxide
1.1 Capacity Nominal Capacity1500mah(1.2A Discharge) Minimum Capacity 1450mAh(0.48ADischarge)
1.2 Nominal Voltage 3.7V
dannyboyohyeah said:I'd rethink my investment strategy, mostly because of those darned chargers (even though it's a real plug 'n play arrangement.) .
nechaus said:the big charger is not worth getting
its just a single charger, Once one pack is done, it will charge the next, so it does not charge all packs at the same time.
These batteries are not worth getting imo unless they are less than $30 per item, its much cheaper to get a small lipo pack
