redorblack
- Joined
- Sep 26, 2009
- Messages
- 142
Today I finally did a ride that got me down to 2 bars on a BBS02 750 watt display. I'm running a Lunacycle 52v 20ah Panasonic (ncrb I think) battery pack in order to get a lot of mileage and longevity. I went with the older cell setup since with that amp/hr rating I'm not pushing the pack at all even climbing at peak wattage reported of 1434 watts. Peak draw is about 1.34 C and I doubt that has been for more than a second or so launching or on a serious grade.
But I digress... My question is about voltages. I've never hit shut off with this pack, but today I got it down to two bars. My inline watt meter says I got home with a resting voltage of 49.9v and had a minimum of 46.04 volts. I'm assuming with 14s that means it was sagging to 3.28v per cell at some point.
Can that be used to calculate how much reserve I actually had left? Anyone know what the pack or controller would have actually cut off at? With a Headway cell pack on my Bafang hub motor, if I saw it start dropping the bars on the 'fuel gauge', it was about to cut off due to low voltage, assuming since it was calibrated for lead acid and didn't know what to do with 16s of LiFePo4.
Oh, secondary question. Do these work and do you think it would handle my 52volt pack even though it says 50v? Or anyone know of one that would actually work for measuring capacity on a 52v pack? http://www.ebay.com/itm/50A-Capacity-Tester-Indicator-coulometer-for-8-50V-48V-Lithium-Lead-acid-Battery-/181427862194?hash=item2a3df17ab2:g:moMAAOSw1ZBUtfpA
