Safe to add balance board to bms regulated battery pack?
vreppeto
I have one of the 5.5a capacitive balance boards https://www.aliexpress.com/item/1A-...122.html?spm=a2g0s.9042311.0.0.27424c4do16ZHS. I m wondering if it is safe to run it in parallel with a cheap chinese bluetooth bms. https://www.aliexpress.com/item/-/33062359787.html?spm=a2g0s.8937460.0.0.9c642e0eiTtu0h
It scared me when I first tried to connect both units at once because there was a large spark. It makes sense that it should be safe to use together in my mind. I cannot picture any kind of short that might cause them to argue. Testing for resistance/continuity between terminals on the balance board shows resistance for a a split second before it opens completely. This seems to be the source of the spark. The bms has short circuit protection. It does not seem to hurt the bms. I disable balancing using software for the bms so the blanace board can work without interruption. What do you all think? Is there any reason the bms might be damaged?
