I plan to upgrade from 4mm2 to 6mm2 phase wires through the axle. Outside the motor I already use 8mm2 phase wires.
There is enough space to put three 6mm2 and six thin (maybe 0.2mm2) PTFE insulated wires through the channel in the axle.
Because I am using ferrofluid, I want to seal the wire exit.
What kind of silicone should I use? It should also flow into all the little areas between the wires.
