serisman's Giant ATX 860 commuter (v2.0)
serisman
Libertyville, IL (near Chicago)
I built version 1.0 (http://www.evalbum.com/4620) back in April 2013 and put over 700 EV miles on it, but recently had to retire it due to some (somewhat expected) issues:
  • The stock hub motor wheel was built with poor quality and exhibited hairline cracks and large dents in the sidewall
  • The capacity of the horribly heavy SLA battery pack (~60lbs) diminished to about a 5 mile range (it started with about a 15 mile range)
  • The rear rack holding the batteries broke when I dismantled it (probably due to all the weight that it had been carrying)
Overall version 1 was a great success and a lot of fun (while it lasted) and proved to me that it was worth investing in this 'hobby'.
So, without further ado, this is version 2.0 (put into commission 8/20/2013)...
Here is the parts list and cost breakdown:
base bike:
  • ~$500.00 - Giant ATX 860 (I have had this bike for about 15 years)
ebike conversion:
rear wheel rebuild:
tools:
non-ebike related upgrades:
Also, (years ago) I did the following upgrades (no idea on the costs anymore):
  • CATEYE TOMO XC bike computer
  • 26x1.5 'road' tires
  • upgraded derailleurs
  • saddle bag
TOTAL: $1,469.35 (~$1,969.35 including base bike)
This is the (Yescom) 48V 1000W direct drive hub motor laced into a Alex DM24 rim with Sapim 13/14 single butted spokes.
The (cheap) stock 6-speed 14t freewheel was replaced with a DNP 7-speed 11t freewheel (enabling pedal assist at higher speeds). This required custom spacers and a rebuild of the wheel to properly dish it (I was already rebuilding the wheel anyway). I used two pieces of electrical conduit for the spacers, as they seemed to be the perfect diameter. These were rough cut to size with a band-saw with a metal blade and the trued up with a metal lathe. Alternatively, it could have easily been done with just a Dremel tool.
My normal commute (to work) is between 7-9 miles (each way) depending on the route I take.
Recently, I have been doing 7 miles to work (3/4 on the paved streets) and 9 miles on the way back (3/4 on the gravel trails).
I average just under 23 minutes to work (including stop lights, etc), and just under 30 minutes back home (including stop lights, etc).
Traveling by car, it is 7.25 miles either way and takes anywhere from 15 to 30 minutes (depends on traffic) with a time or two that it was at least 45 minutes (snow storm). I figure I am saving between $2 and $4 in gas alone for each day that I can take the ebike instead of the car or minivan. (It only takes a penny or two worth of electricity).
I try and pedal a moderate to heavy (100-200 Watts) for exercise, to keep up appearances, and to help the motor/battery pack out. The DNP 7-speed 11t freewheel really comes in handy for this. With the Yescom kit 6-speed 14t freewheel, I wasn't able to hit the smallest gear, so I had to use the 16t gear and couldn't pedal past about 15 mph (or so). After rebuilding the wheel with the DNP (and fixing the spacing issue) I am able to use the 11t gear and can now pedal up to about 22 mph (or so).
I try and keep my speed limited to around 20 mph, and am currently using about 15 Wh per mile (on average).
Oh yeah, for a range test, I went on a 38 mile trail ride last weekend and only used 9.39 Ah (501.7 Wh) which is a little over half the capacity of my battery fully charged. The first and last 7 miles (14 miles total) were with my daughter on the trail-a-bike and we averaged about 11 Wh/mile @ 12 mph (purposely slow to not get to far ahead of the wife and other daughter who were not on ebikes). The middle 24 miles I was on my own (the others stopped at a park to rest/play) and averaged about 17 Wh/mile @ 19 mph.
Based on these results, I should be able to get around 60 miles range on this battery pack at up to 20 mph speeds (with 100-200 watt pedal assist). I am extremely happy with these results.
