One of the common complaints I've seen about typical 18650 builds how they are not easily serviceable and require total disassembly to replace a single cell, as well as not being able to check on individual cells. There are options like vruzend and N.E.S.E modules, but they both have some drawbacks and limitations.
I've thought of a different solution but don't know if I'm missing any drawbacks. Basically you built a more traditional pack with busplates, like you would see on a tesla module or more specifically jonescg's build. But instead of tiny fuse wires or soldering nickel to the busplate, you have a nickel strip spot welded to the battery with a hole drilled into it on the other end, tap a corresponding hole in the bus plate, and bolt the nickel strip directly to the bus plate.
This is obviously more labor intensive and even a small bolt for every cell would add some weight, but the benefit would be a pack that is just as configurable and capable as any, but still be fully serviceable.
What do you guys think? Too much work for too little gain? Any glaring issues?
