I had to try several different forks to find one compatible with my 9c motor and torque arms, then do lots of filing on both the dropout depth, and I had to shorten the length of the shoulder on the axle. The addition of the thin washers made it too long causing the fork to bind. Once I got that all sorted out some c washers and torque arms from ebikes ca fixed me up for a perfect fit install. The forks haven't cracked because the perfect fit hasn't pried them open. Just nice even pressure from the washers. I only run 48v 20 amps, so torque has not been an issue.
I don't know the brand of forks I am using, just that they are cheaper ones in the DH category, so they are beefy enough to file on some. The forks I couldn't use were rockshocks dart II. They, and many other forks have an allen bolt on the bottom of the tube that interfered with the torque arm. So look for that first when choosing a fork.
It's been at least 6 months now with no problems. Most of the alloy fork problems come from not using c washers, or other issues of less than perfect fit. When tightening the nut, the washer applies a spreading force on the drops. Not using the inner washer on a 9c motor can also be a problem, since it has a narrow shoulder. And of course, big power is a problem. Even with steel forks and two torque arms, my first test of 72v 40 amps on another bike had the wheel leap out of the dropouts.
Eventually though, you will want to put a rear hub on that blackcomb, since those nice fat steel dropouts are there on the rear.
