Strange ignored chemistry: Al-Fe2O3
Lowell Massachusetts
I am trying to find more information on aluminum iron secondary batteries.
What I do know is that they were first built at Texas A&M university in 1994, funded by the army in order to power long range series hybrid military trucks. I am unsure but to the best of my knowledge they had a large amount of magnesium added to the aluminum anode so that instead of forming slightly soluble aluminum hydroxide it would instead form an insoluable complex ion; hydrated magnesium aluminate, normally known as hydrated common aluminum spinel. the prototypes were crude flooded plate pocket cells very like the old Edison Nickle Iron or early flooded NiCd types. They claimed between 380 and 450 wh/kg with these early types, and considering most of a plate pocket cell is not the electrode I believe there is large room for improvement on these figures.
Unfortunately there is no free lunch and there are severe drawbacks to this chemistry. Specifications were not available but I have personally spoken to Dr. Ziyad Salameh of the Massachusetts battery evaluation laboratory at the University of Massachusetts in Lowell on the issue of aluminum iron batteries, and we agree on several likely problems. First the severe shape and volume change of the anode will leave it with a cycle life no better than a big box mart quality lead acid system. Secondly the terrible electrical conductivity of spinel will guarantee high peukert losses, high internal resistance, overheating problems, poor efficiency with regards to charging, and require long charging times. The batteries will also require frequent watering, and the voltage is so high that any overcharge or attempt at fast charging will result in the water being dissociated into hydrogen and oxygen, creating a fire hazard thereby preventing unattended charging, trickle charging, or use of a simple, cheap charger.
I have also read of a 3 volt open circuit, 50 ah at C/10 "D" size battery using this chemistry, in a table comparing and contrasting available batteries to laboratory exotics. the paper was published in 2001, and I can no longer find it. The only google-able copy of it was forcibly removed from scribd for copyright infringment a year or two ago. I believe this was a bobbin electrode type, like used in primary alkaline cells, because to achieve this astonishing volumetric energy density nearly the entire battery would have to be active electrode material. unfortunately when wired in very high voltage strings they would sometimes put on a wonderful impression of a thermate grenade, spewing molten iron farther than a garden hose sprays water. What I am guessing happened, but cannot know for sure without obtaining full specs, is they may have used flimsy separators and used pasted electrodes for both anode and cathode. Failure would likely proceed as follows; 1: separator gets compromised, 2: anode and cathode touch each other through hole in separator, 3: short circuit causes internal plasma event, creating enough heat to melt anode and start a thermite reaction. 4: BOOM.
While inherently a risky combination, I see no reason why strong separators and sintered or polymer bound electrodes would not make an acceptable battery. It would require giving up the 50 ah d cell, but even the early plate pocket cells were a large improvement over the latest rc grade LiPO's
Does anyone know if any group is making a safer version of these on a commercial level, and if so where do I buy them. A 400 km range ebike sounds too good to pass up. These cells would also likely be a godsend to anyone looking to make a long range version of the tidalforce or any similar battery in wheel system.
anyone ever heard of these things before, I met someone who says a former UMass Lowell professor was very knowledgeable about them but the university no longer had contact info for him.
I dimly recall seeing one of these being sold off the shelf somewhere in Virginia when I was a kid in the 1990s, iirc about $70 for a pair of 52 ah 3v F cells with the word "aluminum" printed on the side of the cell. I wanted to buy a few but my dad said they were too expensive (I wanted to use them in a boombox or flashlight at the time, not an EV) They are ungoogleable and I can't remember who made them.
Is this the same chemistry as used by the Finnish company Europositron, which enabled them to get a huge risk capital and then disappear?
Frost & Sullivan gave them a price 2005, which helped them to convince investors, but it turned out to most likely be a scam.
They only said it was "aluminum batteries", AFAIK.
They claimed:
Energy Density/Volume: 2100 Wh/litre
Energy Density/Weight: 1330 Wh/kg
Cycle Life: 3000+ cycles
Minimum Working Temperature: - 40C
Maximum Working Temperature: +70C
Life: 10-30 years
Discharge Rate: Adjustable
Website in archive:
http://web.archive.org/web/20080117054752/http://www.europositron.com/en/background.html
No, europositron promised but intentionally did not deliver a 1.5 volt per cell aluminum-air battery with some sort of proprietary aqueous amide electrolyte and a long life high rate bifunctional air cathode. The best story i have been able to obtain is that Partanen took over $2,000,000 usd equivalent claiming that the money would be used for prototypes. According to an expert witness the prototypes as designed would have cost $100,000 to make. Partanen allegedly pocketed the rest and failed to deliver the prototypes.
I read about this about 2 years ago and my memory may have messed up some details.
I am certain however that europositron never sold a single cell.
The batteries in the original post were developed by scientists at Texas A&M university working alone for use in ultra long range series hybrid offroad trucks, with the United States military being the intended initial user. Prototypes were built and successfully cycled, the first ones were plate pocket cells modeled closely after the Edison Nickle-Iron alkaline cells. As such they had very poor electrode mass per overall mass. They still got between 380 and 450 wh/kg
I spoke to my aunt's boyfriend (a veteran from the middle east) who said that the 50 ah "D" cells mentioned in the prior post did exist but I "didn't want to know" what happened to them when they were damaged. Lacking better information I am assuming they turned themselves into little thermite bombs when abused.
