ScooterMan101
2 days ago , I test road a Stromer ST1 Elite,
as well as two other bikes , I will mention later on.
It looks like a quality bike... But,
I was very , Disappointed with the Lack of a twist throttle and sluggish performance !
It has PAS , ONLY , and when testing it with tired legs and slowly peddling , it was Jerky and
the motor felt weak .
Note: the reason I am going with an electric bike is because of Arthritis / Tendinitis in Knees, and Tired legs and Body.
I need to sometimes , often in fact , just use the throttle .
I notice on the PAS bikes that you only go faster when you peddle faster and harder, so PAS is , NOT, for me.
That bike is Expensive, with a 500 watt motor at 36 volts , I thought it would have done much better !
I would buy one used , at a much lower cost,
IF
I could take off the PAS system and use a throttle, and use the full potential of that 500 watt motor.
Who has taken off the PAS and put on a Throttle on the Stromer here on ES ?
I would think it would take a whole different controller ?
Anything Plug right in ?
Cost ?
Performance Level ?
I do like the Build of the Bike, but with only a single chainring in the front , and only 9 in the rear, and being so heavy , the Stromer needs a very , Serious , Upgrade to the Electronics .
IF
Cost ?
Performance Level ?
