msebold
Posts have appeared on Endless Sphere where people apparently have been able to take used Tesla cell modules and construct battery packs for their ebikes. Used packs are available on Ebay (primarily the 24 volt modules). http://www.ebay.com/itm/Tesla-Model-S-battery-module-24V-250Ah-5-3kWh-444-Panasonic-18650-3400mAh-/262333679871?hash=item3d144e48ff:g:OSkAAOSwh-1W5acD&vxp=mtr Although the Tesla cells modules might have significant advantages over a DIY battery pack I have several questions. I am hoping that some knowledgeable persons might chime in here.
1. Is there a realistic or practical way to physically deconstruct or physically modify these 6s74p modules to increase the voltage? My system requires ideally 67 volts at 60 amps continuous (I had been planning a DIY pack using 18650 cells in 18 series).
2. Is there any practical external device I could find that would step up the voltage (to 67-72 volts) and still produce the desired amperage?
3. As these modules appear to be water cooled, do they require a separate fluid pump to use them, or is the cooling system entirely self-contained?
Just a few questions for starters.
Intelligent responses welcomed!
Mike S.
Mike S.
