Through Axle Hub Motor
Bradz estuff
Hi I have a very special bike thats a full carbon fibre Comp edition and wanted to know if there's any hub motors made by anybody that I could use considering the fact it needs through type axle? The crank set is all fully adjustable so a mid drive wont work and I dont want to modify it it in any way other than just adding a motor and back pack type battery setup
ZeroEm said:
Grin
Grin has motors for bikes that are thru axle.
I'm guessing you want a rear motor, front motor might put to much stress on the forks.
Grin's All Axle motor is a front hub.
A "very special" plastic bike is a particularly bad choice for electric conversion. Use a regular, not-special bike for that. It will work out much better.
Was talking about the motors they are getting in like,
Rear Thru-Axle Crystalyte H Series direct drive Ready-to-Roll kit with downtube battery and integrated Baserunner_L10 motor controller. The H35XX hub options is sized for 142x12 thru axle frames, whilt the H40xx hub is for boost size 148x12.. Compatible with screw-on freewheels only, not cassette freehubs. Motors are all stocked unlaced, and feature 0.35mm laminations, a Statorade injection port, and the L10 connector with internal thermistor. For a hand built wheel, please select the rim, spokes, and wheel lacing labour items as well, and expect a 3-4 day additional wheel building delay. Kit includes various PAS or Torque Sensor Options for the V3 Cycle Analyst
They are getting in Rear thru axle motors.
I decided to give up on that idea coz it would have been a waste to hack the bike up so I sold it complete. this the bike I was refering too. would have been cool bike but not real practical to do when its all carbon fibre
