DingusMcGee
If you are going to put pegs on your edirtbike, there is a way to employ the ends of the cranks and pedals to make an MC peg similar in motion to the MC Pivot Pegz.
Here is a peek at the finished product made for an Isis crank
I could not find a flat head metric M12 x 1.0 bolt so I brazed, using high strength nickel-silver rod, (120 ksi yield), a class 12.9 flat head’s head on to the 8mm Allen wrench hole of the OEM Isis shaft/pedal retaining bolt. This bolt, when countersunk, makes for a flat surface through out the steel channel base and the pedal swivel then does not bump any bolt heads — except the stop which is on the bottom side.
A glimpse of the countersunk flathead
The Stop Rotation Mechanism. The gear clamps allow the spindle to be turned when torques get high enough. I figured this permitted rotation of the spindle may lessen the destruction some impact loads (wrecks) can cause. Below, the pedal hinge orientation is the standard 45 degrees up and forward.
