Ian
Hi everyone
I've been mulling over different setups for long distance touring next year, like doing the Southern Tier route by ACA (approx 3000 miles) or possibly the trans-am which goes across central america, and thought it would be good to get some different viewpoints on the motor and battery combos for my particular way of doing it. Has anyone done these routes on an ebike yet? I'd be interested, for instance, to learn more about the charging opportunities along these routes and what's the steepest climbs on the way. My idea is for modest performance ( by ES standards) to minimize chances of electrical or engineering failure:
average 100 miles per day at 15 to 20mph average, top powered speed 20 - 22mph, 1500 watts max.
50 mile range so will need to opportunity charge during stops/lunch etc.
Keep voltage 37v - 48v
credit card tour so staying at motels, minimal gear - carried on extrawheel trailer.
bike is evg iacocca so need a rear hub motor.
Temperatures will be hot for sure some sections and rain likely in east no matter what time of year
I can see two main choices:
lightweight rig: say a 10t upgrade cellman Mac running on 37vc Lipo. Can get 40ah worth on the bike in 4 blocks of 5s 20ah. Two of the 400w passport duo chargers can pump in 10amps per 5S brick. Not too sure the MAC can hack it thermally over the long haul although the upgrades do have the temp sensor and easy to switch out gears and clutch.... Haven't ever used one so not clear on its suitability other than reviews on ES. Not too sure on using Lipo either, - have been using for a few years but its the days you get tired, forget the safety routines, and then the human error factor might come into play that concern me.
mediumweight rig: slow wind 9t or 10t DD basically a 9C or clone with 48v 30ah ping setup. This could be 3 of the 48v10ah packs all paralled using 3 of the ping 48v 5amp chargers. So heavier and no freewheeling, but plug n-play. Trying to fix a probelm Ping on the road not necessarily simple, but I can still keep going using 48v 20ah.
Anything else worth considering?
