KAE
- Joined
- May 22, 2009
- Messages
- 14
I have a rather cheap but very fun ebike, made in China that I have been riding for a while now. It came with a 48V Lead Acid battery pack that has become spongy and worn down. I have a wonderful and very well-made 36V Lithium Iron Phosphate pack that would work great with this bike. The problem is it has an ESC that is preset for a 48V setup with a low voltage cutoff that won't let the bike run on the 36V pack. Its a cheap ESC so its not programmable or re-configurable or any of that. My question is: Is there a way to trick the ESC into seeing 48V for the purposes of tricking the LVC so it doesn't trigger? Or possibly a way to bypass it somehow? The ESC does have a lot of important functions so I don't want to bypass it completely (for example it has sensors that cut off the power to the motor when the brakes are applied, etc. etc.), but I would like to fool it into seeing a 48V pack. Is there a way to "boost" the voltage by 12V or 14.4 or whatever it should be to avoid triggering the LVC, without adding more LiFePO cells????
