jjsylvestre
10 µW
- Joined
- May 26, 2015
- Messages
- 5
Hello,
I'm brand new to EV's and building battery packs so I would like to get some input from you guys on my battery design and where you see this possibly failing. Attached is an image of a split open view of the pack and the complete pack. There are a total of 12 cells summing to 48v. Each cell is composed of 12 18650 Li-Ion batteries that I got from here http://www.ebay.com/itm/251569014683?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Each cell of 12 batteries is connected in series to the next using a aluminum plate (half circle). Each half cylinder is separated by a nonconductive membrane. Note: the top plate will be interconnected (in the Cad file, it is not shown connected). Here is what I am worried about failing- connecting the cells. I was not planning to do any soldering, spot welding, etc. What I had in mind was that the weight of the batteries would be enough to provide a solid connection between the battery terminals and the aluminum plate.
Do you see issues with this?
