The Mighty Volt
Hi folks.
I am putting together these 18650 A123 cells and it seems a straight-up, one-piece 24s10p battery is just going to be too heavy and awkward to go into a ruck-sack like the much smaller batteries I have been using so far.
Its for my BMX and so what I wanted to do was make up some plywood boxes and mount one on each side of the frame, as near to the head-stem./handlebars as possible. I'd probably run a brace of threaded bolt between each one to secure them, I might use polyurethane bushes if the bar is going thru the frame itself.
Should I make two 72v5Ah {24s5p} packs and parallel them, or two 36v10Ah {12s10p} batteries and series them?
To be honest, I prefer to series two packs, that way I have two smaller complete units of 12s10p which can be charged and handled so much easier. It also gives me two 12s10p batteries I can use on a different project should I so feel the need......a 72v5Ah battery really isn't worth squat, on its own, is it??
Anyways I just wanted to check that I am not making any major errors here. It's been a PITA to solder and weld these suckers up with copper shim and I don't want to get it wrong.
What are the rules for connecting individual strings in series and then connecting completed packs in series?? Is it simply a question of making sure they have equal SOC's before connecting?
Are there any such rules which apply for paralleling?
Many thanks.
