maydaverave said:
wineboyrider said:
I use a hobbyking lifepo4 pack in my Honda elite and it is lighter and better than the stock sla and cheaper.
How long have you been using it? Ever completely discharge it? On my other bikes overdischarging isn't a problem but my 1979 xs400 is quirky at best. I have replaced and rewired most of the electrical system but it still has some gremlins. Has anyone come out with a cheap easy lvc yet?
I read somewhere that those Yamaha ignitions need 1-2 amps to excite the generator coils. If its a '79 the headlight is on with the ignition, so if you're leaving the headlight on that means the generator coil is on, too. Unless your battery LVC circuit has a reset breaker function, it might be stuck below the LVC threshold when you need it. Your motorcycle won't start without juice to the generator coils.
I've been dead in the water with the same type of electrical system on an RD400. The best solution I could figure out is to have an SLA as the primary battery combined with a redundant battery for those occasions when the primary gets drained. The SLA has its life shortened every time it goes flat, but it can recover many times. An SLA or a lithium can be used for the redundant battery.
If you put the redundant battery on a relay/solenoid, it normally kicks in during electric start only. Then if you get a boat battery (A or B, A+B) switch you can take the drained battery out of the circuit and use the redundant battery (select B) to start the motor. After the motor is running, select A+B to charge the dead SLA for a few minutes before switching back to it (select A).
This provides a contingency for leaving the ignition on unintentionally and it works great unless you forget to put the battery switch back to A and then drain (A + B) flat. I added an idiot light to remind about (A+B) selection.
If your bike doesn't start up on first kick you might want to check the ignition coils. The stock coils were notorious for becoming weak.
