Using Plastic insullated common wire
bigisland
Why do people buy the silicone wire from HK to get the flexibility and may be uv resistant?
What about the regular electrical wire used for wiring buildings.
As well as being flexable the silicon insulation can handle higher temperatures.
This means that you can intentionally use smaller wire as the wire can run at higher temperatures if you can accept a small voltage drop in the wire.
..and the insulation doesnt melt when you solder connections.
Also remember Ebikes use lower voltage and much higher amperage than household 110/220v systems.
High current needs more copper, and that would get unworkable in solid core wire.
