rkosiorek
I am trying to convert a Meanwell S-240-48 power supply into a CC/CV charger. It is very much differeent than the S-350 series chargers that have been discussed in other threads.
first of - the input section uses a STR83145 voltage sensor to automatically select the input volyage range between 88-132VAc and 176-264VAC. there is a very fancy EMI filter and inrush current limiter.
second - the PWM is based on the TL3843 Current Mode controller chip. current limiting is performed by this chip and is stricly a Hiccup mode protection limiting the input current to the primary coil of the transformer to a safe level. I don't see an easy way to use this for a CC control.
third - the secondary of the transformer feed a fairy simple rectifier and filter section.
forth - Voltage regulation is through a fairly conventional control loop using a TL431 as a shunt regulator controlled by a voltage divider and driving a transistor output HPC932 optocoupler used in the linear mode.
fifth - protection for Over Voltage (ZD7, ZD6)and Over Temperature (separate fan board) is provided via a Triac output Opto Coupler MOC3022. I guess turning on it's LED will force the PWM into hiccup mode.
so i see that if i reduce R48 from 1.5K down to 1.1K i will be in the right range for approximatetly the 58.5V output i am looking for to charge 16S LiFePO4 packs. what i can't figure out is a simple method to implement CC.
any Ideas? any way of using something as simple a Tiberius's single transistor current limiter?
