DrkAngel
1 GW
Vetting the XYD-16 24V 450w DC Brush Motor
While hunting for a replacement, I found the manufactures specs of this motor.
Most surprising was that this 450w "rated" motor is capable of 750w output!
No, not by over volting, simply by removing the current limitation.
Rated 450w with a 26A controller.
70A controller allows 750w output.
Why the 450w rating ... ?
Regulated to prevent damaging heat!
But also, it places maximum motor output right near top speed ... where it is needed, for continuous cruising.
Hunting with the ebike.ca /simulator, I found a motor that matches the XYD-16 motor, at 24V with 13T motor sprocket mod, nearly identically.
The Nine Continents 3004
Proven out by comparing to 25A controller
Much easier to do a direct comparison
At 20mph+, torque, acceleration, efficiency etc. are nearly identical.
Motor is designed for cruising = ideal commuter.
Not ideal for hills, stop and go traffic etc.
You could regear to match your hills ... ?
But I recommend as more of a cruiser than a climber.
Of course ... with pedal assist at lower speeds, performance can be surprisingly good!
Manufactures specs in PDF
http://www.cytron.com.my/usr_attachment/XYD-16 Drawings.pdf
http://donar.messe.de/exhibitor/hannovermesse/2014/M619072/xyd-16-series-eng-296356.pdf
