docnjoj
1 GW
One of U genius EEs came up with the idea, but I remembered it when my 12 volt dc/dc power supply failed on my trike. No lights. Also I foolishly wired 3 devices (2 white leds and a red flasher) in series cause they were each 3-4 volts and it worked for a while. So I found this old cell phone charger and wired in to the 42 volt batt and LO the light appeared. Now also I can wire parallel so I can actually know which device failed. Actually when I tested them individually they all workd fine! Including the 12 volt Power supply!! Much easier to trace parallel circuits! Duh! At least the new power supply is free!
otherDoc
otherDoc
