Just finished putting on the Farfle Swingarm and entry level Rock Shox front and back. Has Cromotor and 150v 24 fet controller 180mm disc in back,165mm disc in front. Still have to wire everything up and fab a battery box. Damn that garage is hot. Only have 24s lipo. Want 28s lipo. Only the triangle and rocker arm left of the original Walmart BSO
RockShox Rear Shock Mounting Hardware-3-Piece Set (1/2X1/2-Inch 50.0x8-mm)
RockShox High-Pressure Shock Pump (300 psi max)
Zoom 25.4mm Adjustable Stem Headset
RockShox XC28 - Coil 100mm 26-Inch 9mm (Black)
RockShox RT3 Monarch rear shock
Farfle fabricated cromoly swingarm with 150mm dropouts
Maxxis Hookworm 26x2.5
Double Leg Kick stand
Home made wiring harnesses
Zombiess 24 fet 150v controller
V2 Cromotor
8 7s5ah Zippy compact lipo for 28s2p
fabricated aluminum panniers
fabricated aluminum cowling
1800 lumen lipo powered headlight
Version 2.3 Cycle Analyst
Crystalyte full twist throttle
generic brake levers with electrical inhibit
Avid BB7 Mountain Disc Brake 160mm front, 185mm rear
Zoom handle bars with a 5" rise
Zoom seat post
Portland Design Works Danger Zone Tail Light
icharger 4010 duo 2 channel charger
meanwell power 1000 w supply
36H QR Front Wheel
Sunlite Alloy Single Speed Crankset - 152mm x 32T, Silver
Finally a road tested roller (rolling chasis) just need to add batteries and controller to the frame.
V2 Cromotor
Zoom seat post
36H QR Front Wheel
