Water in MegaShark pack; chances of revival?
ARod1993
Cambridge, MA
I bought a Sunseeker Fat Tad with a Bafang Ultra on it for a winter commuter this past November; I've been riding it to and from work in a variety of weather (including light snow and in the aftermath of heavy snowfall). I run two 14S7P packs in parallel in Hailong Mega Shark cases (my commute is about 11 miles one way), and last night I noticed that one of my packs was almost empty while the other one was mostly full. I chalked it up to randomness, and rode the trike in today only to find that one of the packs was dead entirely (not charging, not discharging) and there was some corrosion on the charge and discharge terminals. I pulled the pack apart and found that the cell wrapping paper was rather wet (and furthermore that there was condensation on the BMS board). I currently have the cover off and am leaving the battery to dry out; what do you think the chances are that I'll be able to put this pack back into service once it dries out (or just replace the BMS) as opposed to having to throw it away? If I'd realized this was an issue I would have put waterproof sealant on the pack seam.
I think the answer is "no odds can be given on this one."
You are doing the right thing though, drying it out.
After drying it completely.....and I mean completely, meter your cell groups (or cells) to see if the cells are still over say..... 2.5v each. If they are, then you might have a chance of recovering this battery.
Once you are sure the cells or groups are all over 2.5v each, then put it on the charger and see what it does.
If the cell groups are under 2.5v, then your battery is most likely dead.
:D :bolt:
Thanks for the info! I'm considering moving to an ELF or similar, but adding a custom (dramatically stronger) powertrain to it (assuming that it has front and rear suspension
you can spray plasti dip on the sides and get a waterproof bms and drill a drain hole in the case
https://www.amazon.com/15A-100A-Lithium-Battery-Protection-Balance/dp/B08DR5XRT2/ref=sr_1_1?dchild=1&keywords=14s+bms&qid=1615355506&sr=8-1
