ShoGinn
So, Picked up this Cycle Analyst used from a guy her on the forum, and it checks out fine, shows the correct Amps/Watts speed etc but it has one quirk..
The details:
CA-DPS 2.23 , External Shunt (1mOhm) using Anderson Power Poles on both ends.
Bike is a Juiced Riders ODK V2..
Not many more details on what is being used..
I hooked it all up as per the manual (and common sense and experience)..
Powered it up and noticed a approx -100watts... and it would fluxuate +-40
went into the advanced settings and ensured all was set right, also zeroed out the values MULTIPLE times..
Unplugged the controller side of the shunt to see if there was a weird issue... no change.
I was moving the wires with my hand when I saw the watts immediately went to 0. SO I thought it was a wire bad or a bad solder connection etc (it is used).
Opened up the back on my workbench and found nothing visual, broke out the fluke meter and started checking the connections... could find no issues, all had great continuity...
I was baffled and frankly a bit angry.
I got it back on the bike and decided to separate all the wires (speed sensor and CA-DP plug) while powered up... I noticed that when I grabbed the speed sensor wire with a closed fist (as in the video below) it would go down to 0.
I also noticed that when touching the case of the CA it would also drop down to 0.
This is beyond my bug tracking! anyone have any ideas? I sent a fairly similar e-mail to Grin..
And as they say a picture is worth a thousand words, so here is a video 1:11 long so at 27fps is about 2 million words. have at it!
[youtube]nRPRML-TPzo[/youtube]
The details:
