On inexpensive, stamped sheet metal brakes, adjusting the screws may not be enough to correct brake drag. The springs on these brakes are not made from quality spring steel, but soft wire. Also, tolerances in the brake pivots are not good, so one arm may bind on its pivot more than the other. One work-around is to bend the wire springs themselves.
Also, on brakes, like the one shown, the adjustable end of the spring is anchored to the plastic part with the screw in it. Over time, the plastic piece cracks, making adjustment impossible.
