Hey, I just derived an easy to use formula for calculating the internal resistance of your battery(I didn't know of it until now, so I apologize for any redundancy this information might contain) just from knowing the resting voltage(the voltage when there's no throttle for some period of time which is like 5-25 seconds), and the "working"/"draining" voltage at a given "working/draining" current, all of which the cycle analyst sees.
Where R_b is the internal resistance, I the current, V_0 the resting voltage and V the drain voltage...
So, what battery are you using and what did you calculate? Make sure to mention the nominal voltage and capacity.
I did a "rough" calculation on my battery(I just recalled values that I seem to see, which might be off by a couple of volts and, thus, several tens of milli-ohms), and it seems my Ping 1.0 10AH 48V battery has an internal resistance of 200 mOhms which comes to 12.5 mOhms for each 10AH 2-cell group. I think that's possibly a little high, but I don't know what the "standards" are.
