Hi,
I'd like to parallel charge two Li-ion batteries, one is the original 36V 11Ah of my ebike and the other will be a 36V 13Ah extender battery pack. For this I'll use the original charger of my ebike battery and add a Y cable with XT60 connectors to charge the extender at the same time. To prevent any cross current flow between the batteries in case of unequal voltage when they're hooked up, I'm going to use schottky diodes. I have two questions regarding that:
1) The charger output is 36V 4A so when charging only one battery the diode should handle the 4A and when charging both batteries in parallel each diode will see roughly 2A. I could find schottky diodes rated for 60V and either 5A or 8A. Should I go for 8A or is it preferable to go with the 5A (if the diode has to handle 4A)? In other words should the diode work close to its nominal voltage (in that case the 5A should be preferable) or is it better if the diode can handle a larger current such as 8A?
2) Is it OK to solder the diode onto a wire and cover everything with heatshrink tubing?
Thanks for your input!
