SniperGaulois
There are solder alloys that melt at 130-150 degrees, and my Panasonic batteries can handle 220'C according the the specifications. With 90 degrees to spare prior to overheating the batteries, it should be possible to weld them. Most of the research has gone towards spot welding, when it could be possible to weld the batteries normally. So with 140 degrees solder, if you put all the batteries in a line, perhaps it's possible to weld one battery every 10 seconds... Afterwards, it would be only necessary to line up some nickel strips or 14awg aluminium? it's more conductive than nickel, and to make batteries in a way that is more reversible that spot welding. why dont people use aluminium, it is so cheap and it is more than twice as conductive as nickel? aluminium is used in power grids and airplanes: https://en.wikipedia.org/wiki/Aluminum_wire it's light and it can be used for low temperature welding. I could well see myself getting some 140 degrees top range solder, aluminium ribbon, and making a pack in that fashion, now that i have just bought 150 euros of spot welding equipment online. a waste of money?
