Patriot
- Joined
- Aug 7, 2008
- Messages
- 511
Will hot glue insulate?
I have a couple of 6-pin connectors that will have one side of it exposed inside my box. Basically, the side where the wire leads solder to the little pins. Anyway, I'm worried about something hitting them, and damaging them.
So, I thought coating the base of the connector, in between all the pins, would help make it stronger. Also, to keep moisture out.
I am also worried about the glue being conductive between the pins, thus shorting them out.
Will this work?
Will this work?
