I have a 48v 20ah LifePO4 battery to wire up with these components: battery + wire to a fuse holder to a ping provided diode so I can parallel this battery with another. So there are 4 connections before getting to the controller. Is this too many connections to use anderson 45 amp connectors? I like the ability to plug and unplug but I don't want to cause any problems.
Next question, I also have some anderson SB50 connectors and that is the connector on the crystalite 48v 40a controller. Is there a crimp tool for the SB50 connector or is it acceptable to solder this connector using a propane torch, rosin flux and electrical solder?
Thanks for the help/advice.
