Hey guys, just picked up a used zero MX for a couple hundred bucks with no battery pack. I have decided to assemble one from turnigy lipoly packs and am in the process of ordering everything I need but first I need to nail down some details.
What guage wire is suggested?
Is the Anderson SB50 connector/SMH SY50 the same as what's on my bike? (it shows the name brand anderson with 50A/600V rating).
What voltage is suggested? From what I can gather 14s is the stock voltage? I have also seen one other reference to 74v but that was a 2012 DS. I'm thinking of running 14s6p 5000-5300mah packs
For wiring I'm thinking of using EC5 connectors, dean's or bullet connectors but I haven't really figured out how to wire it all into a harness with larger guage wire without going with some sort of terminal block style setup. I have an 80 watt weller I use to solder my RC helicopter packs with but I don't know how it will work on anything over 10 guage wire. Any tips here would be greatly appreciated.
As of right now I have an rc helicopter 12s 4000 mah pack hooked up with some 20 guage wire rigged just to see if the electronics and all work. Photos are below, I'm able to hear a click that sounds like a relay and the "dash" lights up but I'm not sure of the controller/motor's condition as it will not turn over and if it does I expect the wire to quickly melt but I would like to test it before ordering $1000+ in packs.
Finally, I'm not against going with pre-assembled packs if the price is close to the Turnigy packs. I do have experience with soldering and wiring up series and parallel packs, just not at this scale.
