Zero Motorcycle Replacement Pack
Postby cenesdelavega » Fri May 04, 2012 7:30 am
Anyone have any ideas on replacing my Zero-X and MX batteries? Mine seem to be losing power - going up a steep hill, they just don't have the oomph they used to have. They are the standard 2010 Molycel battery packs. The ones from Zero used to be pretty pricey, and don't even appear on their web site any more. Thanks! Roger
cenesdelavega
Re: Zero Motorcycle Replacement Pack
Postby amberwolf » Fri May 04, 2012 3:05 pm
If you're up to building your own pack, there are a few options, including the A123 20Ah cells that appear to flooding the market right now.
If you look around, there is a thread about some pre-built pack modules, probably easy to build your own pack from those.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby 999zip999 » Fri May 04, 2012 6:07 pm
How many volts ect.
999zip999
Postby cenesdelavega » Sat May 05, 2012 11:46 am
They are built from these cells: http://www.molicel.com/ca/pdf/IMR26700.pdf .
There are 14 banks in series, to get a total of 53.2V at 3.8 volts (nominal) each. Each bank has 12 cells in parallel for a total of 168 cells. Each cell has a nominal capacity of 2.9Ah. Total capacity is 1850 Wh. The controller is rated to pull a maximum of 300A.
Would a pack made with the A123 20Ah cells source this much power? I'd really like less voltage sag, and longer life than the Molicels.
Thanks, Roger
cenesdelavega
Postby picasso » Sat May 05, 2012 8:58 pm
The drop with a123 will be well under what the e molicel can do. All of the new zero packs are a123.
picasso
Postby Doctorbass » Sat May 05, 2012 9:03 pm
picasso wrote:All of the new zero packs are a123.
Oops!.. the 2012 are made of EIG cells :lol: not A123.
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby Doctorbass » Sat May 05, 2012 9:09 pm
Problem is that the original BMS of the zero is made for a range of 3.0 to 4.2V and the A123 are 2.0 to 3.6V so you can not just replace them by the A123 and hope that the BMS will work.
I have a zero 2011 with the 3.8kWh pack ( 14s24p) of the emoli cells 2.9Ah . I opened the battery to add some baalnce connector in and i can say that you have alot of room to include a new battery setup and a new BMS as well.. but i'm not sure if your actual zero ( a 2010?) have a BMS that communicate with the ECU to enable it to work.. like mine is.
The LiFePO4 cells like A123 need to be 16s to match the 14s pack of the zero. maybe building your own pack with the A123 pouch and to make a circuit that fake the 14s cells detected by the BMS to make it "detect" the 14s limn cells but it would just have to be a 14 resistor in serie( voltage divider) that fake the original cells of the zero and enabling the ECU from the signal of the BMS that detect the fake cells.
Than
build your new pack in 16s A123 and connect it to teh main positive and main negative.. ?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby picasso » Sat May 05, 2012 9:58 pm
Odd I was at zero a week back and saw a stack cells, I asked if those guys have changed to the pouch a123 cells and was told yes....
The other problem with a change in cell type is the dash on the MX. It will pull out the solenoid on signal from the BMS. Havent looked if its active or just passive signal.
picasso
Postby liveforphysics » Sat May 05, 2012 10:12 pm
picasso wrote:Odd I was at zero a week back and saw a stack cells, I asked if those guys have changed to the pouch a123 cells and was told yes....
You asked the wrong person evidently.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby cenesdelavega » Sun May 06, 2012 4:30 am
If you look on the EIG site, indeed, they are crowing loudly about the Zero deal. However, which EIG cell did they choose? I talked to Zero a couple months back and they said they have raised the 2012 pack voltage so I would need to replace just about everything in order to use their new batteries (if they are even selling them). Personally, I think there will be a reasonable demand for replacement 2009-2011 Zero packs now and in the next couple years as the Molicel packs bite the dust. Otherwise there will be a lot of Zero-X and MX that will be gathering dust. A drop-in A123 or EIG pack (or other cell type) would be very cool (and fast!). Any takers? I'm willing to be a guinea pig... Or, if not, I'll try to build my own. At one time I was a EE... Some preliminary questions:
1) Best place to buy A123 or EIG cells or modules?
2) Can I use the existing Zero charger (probably yes, if I use the "fake 14S" method)
4) If I use the fake 14S method, then how should I keep the real 16s cells balanced?
cenesdelavega
Postby picasso » Sun May 06, 2012 5:39 pm
1) http://www.victpower.cn seems to be the cheap a123 suppler.
2) The charger can be reprogrammed, I have never done it. But you can find info on the deltaQ chargers here on this forum and also DIY.
3) I would think one would just ditch the ZERO BMS, I have a newer "MX" bms here and it is now sealed in epoxy. No way to get at any tap points to see what it is doing. The newer MX batts have a metal plate do help dissipate the heat from top balancing.
I bet zero gets a module from EIG and not naked cells. But I did see a stack of pouch cells at Zero that looked a heck of allot like the a123 sized cells.
picasso
Postby Ykick » Sun May 06, 2012 9:33 pm
Ya think? LOL...
Ykick
Postby Doctorbass » Sun May 06, 2012 10:03 pm
Ya think? LOL...
Yes it's EIG
but if you preffer thinking it'S A123 it's up to you :lol:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Ykick » Sun May 06, 2012 10:29 pm
Doctorbass wrote:
Ykick wrote:
Ya think? LOL...
Yes it's EIG
Doc
Doc, I was agreeing wholeheartedly with Luke...
Ykick
Postby Doctorbass » Sun May 06, 2012 11:29 pm
Ykick wrote:
Doctorbass wrote:
Ykick wrote:
Ya think? LOL...
Yes it's EIG
Doc
All right ! :wink:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby cassschr1 » Mon May 07, 2012 8:07 am
Luke, you need to tell people where you work.
cassschr1
Return to Battery Technology
Who is online
Users browsing this forum: webfootguy and 7 guests
