thedarlington wrote:this info is out there and spread out all over, so here's a dedicated "BMS free zone"thread specifically for this, when starting out BMS can easily be the biggest pain to understand, most don't even have a brand and each have obscure specs making them hard to compare, and then many very easily fail, often the most frequent failure point to a non working ebike. Its easily the shadiest part to ebikes with little details and then trying to compare them... so instead here's a thread to those of us who preffer a more purist simpler solution, yes you do need to watch #'s a bit more closely but it's also more rewarding to know exactly whats going on with your ebike, sorta like manual vs automatic.
rule of thumb>>> [#Series * Voltage] & [#Parallel * mil AMP hours] = total Battery Volt & mAmphrs ... LIFEPO4 @ 3.3v, & LIPO @ 3.7v
thedarlington wrote:some options for you are:
LIPO - - simple and robust batteries, small and lightweight battery packs which are not as delicate voltagewise as lifepo4, many cheap low voltage alarms ($1) set to go, but more expensive and dont last as long, works out to about double lifepo4 cost? (citation needed) manual balancing (is it needed for lipo?)
Jeremy Harris wrote:Here is a brief run down on the various types of LiPo cells and the relevant voltages, etc:
LiCoO2 - Commonly used for RC type LiPo packs, 3.7V nominal, 4.2V maximum, no lower than 3V on deep discharge (preferably no lower than 3.5 to 3.6V for best life).
LiMnO4 - Not that common, nominal voltage 4V, maximum about 4.5V, low energy density when compared to LiCoO2
LiNiO2 - high energy density, nominal voltage 3.5V, maximum about 4V, no lower than 3V on deep discharge
LiFePO4 - medium energy density, potentially the safest current LiPo chemistry, 3.3V nominal, 3.65V to 3.7V maximum, no lower than 2.7V on deep discharge
LiCo1/3Ni1/3Mn1/3O2 - higher energy density than LiCoO2, 3.6V nominal, maximum about 4V, no lower than about 3V on deep discharge
LiNiMnO2 - very high energy density, not yet commonly available, 4.2V nominal, maximum and minimum not known
thedarlington wrote:good points i dont run lipo
amberwolf wrote:I wikied this list here:
http://www.endless-sphere.com/w/index.p ... LiPo#Types
but I would like to add this note to the last one, if you are referring to "NMC" types:
"(actually is known from datasheets such as EIG's: http://www.eigbattery.com/eng/product/C020.pdf : 3.65V nominal, min recommended 3.0V, absolute min 2.5V, max charge 4.15V.)"
thedarlington wrote:thanks jeremy yea life, for some reason the chemistries mentioned here have always been life or lifepo4, SLA, Nimh, and then the notorious lipo aka hobby king packs, so these are LicoO2 then? i dont follow them so close just picked that term up from common use here, i think Rc retailers like HK are to blame for spreading bad info, i like HK but they should emphasize tech specs over buzzwords and marketing, sometimes its hard to even compare features/functions of their stuff bc most are not listed, no regrets goin with the better ebay copies, and btw ill be using either ethernet, VGA ,or IDE, to hook these things up
999zip999 wrote:Are those single strand sense wires ?
Users browsing this forum: BentMike, lcrewse, Rassy and 10 guests
