Can anyone identify this BMS connector? It looks like an 80% JST connector. It seems to have the same pin spacing as ThunderPower connectors, but this one is 10s, and ThunderPower seems to only go to 8s in a single connector plug.
OK. Learned something there. What you are showing is the JST-XH connector that has a 2.5mm pitch. That's the larger connector on these packs. I didn't realize that JST was a company name. It is possible that the connector I'm looking for is also a JST brand connector. I'll look through their connectors with a 2mm pitch and see if they have one with a 2mm pitch. The smaller connector in the photos is definitely less than 2.5mm. I'm pretty sure it is 2mm.
Thanks a bunch everyone. I think that is probably it. I'll look closer when I get home tonight. It looks like I can get them on ebay pretty cheaply. Cool beans!
