CRYSTALYTE motor 5300 to 5400 Winding Electrical Information
Archive of useful information. This is not a discussion area.
Postby Doctorbass » Sat Jun 19, 2010 10:22 pm
This thread is to sort all MEASURED caracteristic of the X5 motors
after all.. it's the most powerfull hub motor we can get for bicycle...!
Every time i dissassemble one i carefully measure and note everything about them that is under the cover.
( all with calibrated fluke equipment)
5302:
-winding
--number of strands: 10
--size of each strands: AWG 20 ( 0.032"dia)
--All strands = to one 10 AWG
--inductance bewteen two phase wire: 79uH
--DC resistance between two phase wire: 0.045ohm (direct to winding)
-number of pole:12
-number of magnets: 24
5303:
-winding:
--number of strands: 8
--size of each strands: AWG 20 ( 0.033"dia)
--All strands = to one AWG 11 conductor
--inductance between two phase wire: 169uH
--DC resistance between two phase wire:0.097ohm(direct to winding) and 0.103ohm(thru the anderson connector)
-number of pole: 12
5304:
-winding:
--number of strands: 5
-number of pole:
-number of magnets:
5305:
-winding:
--number of strands: 4
--size of each strands: AWG 21 (0.029'")
--All strands = to one AWG 15 conductor
--DC resistance between two phase wire: 0.142ohm
-number of pole:
-number of magnets:
5306:
-winding:
-number of pole:
-number of magnets:
5403:
-winding:
--size of each strands: AWG 20 (0.032'")
--inductance between two phase wire: 297uH
--DC resistance between two phase wire: 0.104ohm
-number of pole: 12
AWG reference is here:
http://www.powerstream.com/Wire_Size.htm
Some older 5305 reference are here:http://endless-sphere.com/forums/viewtopic.php?f=2&t=4404&hilit=parameter+5305
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Re: X5 Winding Electrical Informations
Postby steveo » Tue Jun 22, 2010 3:36 pm
Hey doc,
You should change the pole count for x5303 to 14 poles.. unless .. i'm wrong :P
-steveo
http://www.youtube.com/user/trdfreak03
Project Deathtrap
viewtopic.php?f=6&t=46755
2002 Honda Insight Mk1 hybrid/Gridcharger/Mima & FAS/obd2c&c gauge/50s2p a123 40ah battery/100mpg+ /PP50 bms
For sale/barter thread
viewtopic.php?f=9&t=44316&p=645130#p645130
steveos repairs thread
viewtopic.php?f=3&t=27170
steveo
Postby Doctorbass » Tue Jun 22, 2010 4:26 pm
steveo wrote:Hey doc,
-steveo
Hey Steveo,
Thanks i 'll double check that but i've always thought that all X5 have 12 poles.. just like justin is suggesting on about the X5 motor serie?
If you have some more info to add to these informations please PM me them.. i'll add them.. also i wanna know about the 5306 if it's 4 strands of wire and what is the diameter of that wire on the winding ( measured)
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Tue Jun 29, 2010 10:17 pm
Some typical pics of a X5 stator :
( here is a 5303 being converted to a 5303 and 5306!!)
... with some modification as well; 6x Relay, heat shring on the phase wire strands, all phase are splitted into two independent winding...
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Re: CRYSTALYTE motor 5302 to 06 Winding Electrical Informati
Postby Doctorbass » Sun Apr 01, 2012 10:00 pm
Update 1 april 2012:
Added: Crystalyte 5403 motor
Thread of the complete review and pics here:http://www.endless-sphere.com/forums/viewtopic.php?f=30&t=38300
ELECTRICAL PARAMETERS:
Phase to Phase DC resistance ( direct at the junction of the winding terminal and the phase wire so no phase wire resistance included)
Current: 10.0A, Voltage across phase to phase 1.042V Resistance = 104.2 miliohm
Inductance Phase to Phase ( measured across the phase wire wich change nothing to the inductance of the winding)
= 341mH
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Return to Technical Reference Area
Who is online
Users browsing this forum: No registered users and 1 guest
