BVH
- Joined
- Mar 26, 2009
- Messages
- 411
I need a wiring diagram of a 4-wire half-twist "48 system Volt" throttle with the name - as best as I can tell- "Pthe" or "dthe" molded all over the rubber grip. I tried searching for these two names on the web with no results. I think one wire is for the battery condition led's and the other 3 are the standard 3-wire for a standard throttle. Wire colors are: Red, White, Black, Purple. I'm guessing red is the 5V supply, White is the 0-5V return signal, Black is ground and Purple is battery Voltage. Any help with links to a website, diagram or personal knowledge of this throttle would be appreciated.
